How much does your average starter cost?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Tuskadero, May 21, 2001.
  1. Tuskadero
    Tuskadero Registered Member
    Jul 14, 2000
    91
    Southern California
    Hello,
    I think my starter is bad, I have a 1989 Blazer and I was wondering how much a new one is going to cost me. Can anyone help me out thanks, Heather
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    You can probably find one for $30-40, but you'll probably have to replace it soon, too. I got a lifteime warranty one at NAPA for $80 a little while ago.
    90K5
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    if you actually use your 4x4 you wont want 'average' starter. they make a special 4x4 model with 'closed' snout and special seal to protect the windings. of course because it is 'special' you pay a premium, i paid $134.75+tax CDN in 1994 from a rebuilder and it is still kicking fine.
    not sure if this is relavent but part#701 std3884g
    obviously i keep my reciepts
    hope that helps some
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I picked up a $40 one with a lifetime warranty from Pep Boys. I also picked up a new seloniod and a rebuild kit (I think $24 for both) just incase I am out in BFE when it goes again.
    Do you by any chance have hedders? I think that is what did mine in. A heat shield will be my next mod.
    '71 Blazer CST with alot of rust
  5. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I would recomend geting a good quality one from Napa or even a new AC Delco depending on what prices you can find in your area. Starters... cheapy starters and alternators have this crazy knack for crapping out 3 months down the road. I get all my starters and alternators from a custom place that rebuilds them... they really know their stuff and are pretty affordable, maybe ask a trustworthy local shop where they get there's from.
    1987 Chevy K5 Blazer- 350 TBI
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I just read your other post, and if your satrter is really going out, and your truck wont start, after checking the connections at the starter, try hitting it with a hammer a few times. My starter went out a few months ago, and I had to carry a hammer with me and hit it every time before I tried to start it, otherwise it wouldn't start.
    90K5
  7. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    i work at a parts store, and my suggestion is to drop the few extra $'s for a lifetime starter. While i do see a few of these come back as warranties, there are far more of the cheap 1year or 3year warranties come back. You get what you pay for. I would say $40 to $45 for a lifetime warrantied starter is reasonable.
    eric
    Hell, it don't really matter....it's just for my race car.
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I just replied in your other post. But here it is again.
    The one in my S-10 had a loose post on the solenoid. (sp) It kept it from starting. Just clicks. Tried the jumpstart thing and everything else before replacing it.
    Just a thought,
    P.S. Make sure you have the auto parts store test the new starter before you leave the place. I have seen 3 bad ones in 2 years. Two were in the store, can you guess where the one was??
    John
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '84 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allsion Auto
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    How is that one different from the Autozone "Off-road version" starters that sell for $40 lifetime? They are almost completely enclosed.
    Let me tell you what the problems are with small block starters:
    1) solenoid contacts pit and corrode
    2) Wiring doesn't give enough juice to the solenoid coil
    3) Stupid thing has bushings in the end instead of bearings with snap rings. All you have to do is get some wear and the rotor can move forward and back, taking the windings out of the ideal location for making torque.
    The cheap starters are worse only because they use softer end caps which speed up the wear and cheaper solenoid contacts.
    <font color=green>"I don't have the brains for business. I want to go into politics" -Mao Xinyu </font color=green>
  10. nd_4_mud
    nd_4_mud Registered Member
    Mar 16, 2001
    40
    new jersey
    I paid 45 for one from pep boys. And i keep the receipt. That way they will replace it. I have had the same starter for about 1 and a half years know. And it has had mud and sand all up in it and still no problems. I guess i got lucky.
