how much flex
Discussion in 'The Garage' started by basing110, Aug 8, 2005.
  1. basing110
    basing110 1/2 ton status
    Aug 4, 2005
    298
    san diego
    alright i am going to do tuff country suspension 2" lift 52" spring swap with 7.25 eye to eye shackles up front with a zero rate and 4" lift 56" rear springs with my ord 4" shackle flip ,i may be taking out a leaf or two depending on how the ride height comes out ..keep in mind i am running 44" boggers ... how much flex should i expect from this swap? anyone know about how many inches i will cycle? and is this a good setup or will it be to stiff?i was also thinking about just running 4" lift tuff country springs up front because they have 325 rate compared to the 405 of the 52" leaves what should i do?
  2. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Sounds like you'd be too high in the back. I'm no chevy guru. See my sig.
  3. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I had those exact springs on my truck with a 3" body lift and it would have cleared 44's quite well. I would say the rear with 6" shackles provided ~9" suspension lift and the front with 7.25" shackles provided ~7-8"
    It was too high for what I wanted, so I only had them on there for a few days. Thus, I have both the TC 2" 52's and the 4" 56's for sale if you're interested.
    The 52" TC's wouldbe quite a bit more flexy than stock-length 4" springs. You will most likley be hard pressed to find ~8" lift and still be flexible without going with 52" TC's
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Sounds like you'll have a 6-7" lift up front, and an easy 9" in the rear. 4" 52's up front should make about an 8".
  5. basing110
    Aug 4, 2005
    298
    san diego
    how much do you want for those springs? and you think its 8-9" lift without any blocks? email me how much you want chameleon_mb@yahoo.com also can you send some pics of that setup so i can see about what i am looking at? do you know how much flex you were getting about?
  6. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    No, he said he has a 3" body lift.
