How much fluid can a clocked np208 hold? What is minimum not to burn it up?
Discussion in 'The Garage' started by xtrmjoe, Jan 17, 2005.
  1. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    How much flud is the minimum for a np208 to not overheat? I clocked it 4" and lowered it 1" so it does not want to hold much fliud but dont want to burn it up.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my clocked 208 can hold more fluid than spec, i just put in 4.5 quarts and havn't had a problem yet.
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    manual says 4-5 quarts
  4. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    I know the manual says 4-5 but I think I only have 2-3 in it right now and I hope that will be good enough, since it is synthetic I think I will be ok but am looking for actual expierences.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i would run more than 2-3. even if it is synthetic.
  6. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    IIRC, the 208 doesn't have an internal pump, it's splash-lubricated. So, the oil level in the clocked 'case has to be high enough to cover the bearings & gears as much as they were covered in the stock 'case. If not, it WILL cook something.
