How much goes in my radiator?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Nov 19, 2001.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I recently pulled my radiator to have it flushed and fix a few cracks. I disconected the overflow container to use the connections for hooking up to something else. About how much fluid should i put in my radiator?
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. Locked front and back.
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    About 1 to 1.5 Gallons.
    About 4 to 6 Quarts.
  3. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    Would you sugest a 50/50 mixture of water/anti-freeze?
  4. Executioner
    Feb 22, 2000
    1,530
    Only if you will be were it gets really cold !
    Try to guess the coldess it will be and give your guess an extra 10 degree's.
    When I lived in Seattle winters got to 20 degs once every 10 years, so I figured it may get to 10 degs.
    Depending on your flavor of Anti- frez, usually on the back it will tell ya what ratio will egual what degs.
    More is always better ?
