How much heat is too much - torching off spring perches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by djohnsn, Sep 5, 2002.
  1. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    The shop that I used to remove the spring perches from my 14-bolt torched them off. They said that they had to use "a lot of heat". These were the solid perches (82 van 14-bolt). The floor had melted chunks of metal all over it. How can I tell if my axle housing is damaged from too much heat? Is damage likely?
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Take a reliable straight edge and check the opposite (bottom) area of the axle tube. If the heat was excessive enough the tube may have distorted. If the straight edge shows anything other than a dead straight tube you can confirm if the tubes are now bent and how much by measuring the inside dimension between the drums at the top and the bottom. Ideally it should measure the same top and bottom...
    I have a 14 under my truck and another in the carport and both measure within 1/8" top and bottom of the drum. One has original perches and the other I just removed the perches.
    Rene
  3. djohnsn
    327
    Plano, Texas
    Thanks for the response Rene. I will check it out with a straightedge and measure between the drums. Why didn't I think about measuring between the drums? /forums/images/icons/smirk.gif
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I only thought of it while I was replying...
    If you do find the tubes are bent a little it can be straightened the same way it was bent. Get the new perches on first though. Apply some torch heat to an area on the opposite side of the axle tube and let it cool...try and approximate the amount of heat that went into the other side originally. The area that you heat will expand as it warms up but when it cools will actually shrink some. It should be enough to pull it back to straight. Heat an area about the size of a silver dollar to start...
    Rene
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Why wouldn't they just use a grinder?
  6. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    time is money---especially in shops---say $50/hr
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Arc air is faster...less heat if you do it right too./forums/images/icons/smile.gif
    Rene
  8. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I agree... should have used a grinder. I had mine off witha grinder a big hammer in like 15 minutes per perch. Including clean up work to weld on the new perch and clean up where the old one was.
    Ken H.
  9. cityfarmer2
    cityfarmer2 Guest
    Just cut mine off with a grinder any one have an idea of the distance between perch's should bbe and at what angle for a 6 inch lift? Sorry for butting in but seems like good information being put out so thanks.....
