how much is a cheap set of plug wires
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigoltrux77, Oct 1, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    i want to know how much a cheap set of plug wires is. Im gonna invest in MSD christmas time, but i need cheapos now.
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    summit racing plug wires. pretty good, too.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    The only problem with cheap wires is they cost you about $1,000,000 in headaches. I would HIGHLY recommend buying a quality set now if you need them.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check out the Taylor Spiro-Pro wires at www.summitracing.com . I run 'em on everything I own. One set has been in use for about 8 years now and they still work great! So spend $50 or so once and be done. /forums/images/graemlins/cool.gif
  5. dyeager535
    26,980
    I haven't had any problems to speak of, with my Schucks El Cheapo plug wires. These are gray ones, not Autolite, however, they ahve a lifetime warranty, so if I *think* they are the problem, I'll just return them and get new ones.
    I believe they ran around $25-35, and I've been running the same set for two years.
    One "trick" that some people use apparently, is plug wires from an Olds V8 (say, a 1985 Cutlass with the 307/5 Liter) because the boots are "straight" and tend to keep the wires away from headers or manifolds a bit better. Haven't needed to try this myself.
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    I run Bosch wires from Autozone. $30 with lifetime warranty. I just take them in every two years or so for a fresh set. Not awful wires, but also not the best. They even let me buy a new set and then return the old set for a refund, which makes changing them more convenient.
