How much is enough to grind/cut off?
Discussion in 'The Garage' started by Joshinator, Mar 7, 2005.
  1. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    Ive got a 700r4 goin to a NP205 with the figure 8 adapter along with a spacer and a splined collar. I noticed that my output shaft on the 700r4 is a tad too long (1/16" gap between spacer and tranny) for it all to slip together. I dont want to change the output shaft, so i was thinking i could cut off a small peice or grind it off. How much should i remove, just the 1/16" or do i need to remove more? Thanks in advance.
    Josh
  2. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Stupid question, but are you sure you have the right adapter? There is definitely a specific adapter that should fit. I could be wrong though.
    If you were to cut off the shaft I would be careful so that you don't get it to hot and burn up the tranny output seal. Maybe just cut a little bit at a time.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, I have a 700-205 combo with a 350-to-205 adapter + spacer. You need to trim the shaft just a bit. 1/8? would be plenty. Its not a big deal, and you don't have to remove the shaft from the tranny to do it.
    j
  4. blacksheep10
    blacksheep10 Registered Member
    Feb 16, 2005
    37
    Paola, KS
    port-a-band
  5. Joshinator
    Jan 19, 2005
    58
    Sulphur Louisiana
    Thanks guys
    Hey Guys, thanks alot, i was thinkin about an 1/8" also, but i needed a little reassurence before i pulled out the power tools on my output shaft.
