How much is my lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by horsepit, Jan 9, 2002.
  1. horsepit
    horsepit Registered Member
    Nov 25, 2001
    63
    Ventura, CA
    Just bought a 1987 Blazer that has a lift. The owner didn't install it. He thinks it's a 4" but doesn't know. How can I tell? Where are the measuring points to compare to stock?
    1987 Blazer, Rancho 4"
  2. measure from the top of your front axle tube to the bottom of the bumpstop bracket. somewhere around 12-13 inches is a 4 inch lift. variables would be winch, big or small block, age of springs and so on. there was a thread on this a while back and everyone put in their data. might be able to find it- do a search.
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I usually look at the steering to tell me if it doesn't have crossover on it. If it has the stock pitman arm on it and the steering arm for correction, the drag link should be about perfectly straight across if it's a 4" lift with that arm.
    Tim
