How much is this worth
Discussion in 'The Garage' started by pplblazerdude, Jan 27, 2004.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    In the local trading post i found a dana 44 and a 14 bolt full floater with 4.10 out of a 70's model 3/4 ton hints dana 44 for 350 are they worth this or are they worth passing up.
    CLint
  2. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    the places i've priced here seemed to be pretty close to that is that for both or just the front if its for both jump on it . /forums/images/graemlins/waytogo.gif
  3. pplblazerdude
    Jul 18, 2002
    242
    yeah it is for both of them. I just dont know if i need them im only runing 35s but i figurie i may go 37 or 38 in a few years. A money is tight as im 16 and i need to rebuild my motor to.
    Clint
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    If your already "thinking" your going 37's or 38's, that means you WILL go 37's or 38's! Trust me, Once you get the disease, there's NO CURE!! do yourself a favor and grab them if you can. Do you know Exactly what year? look at the passenger side knuckle, see if it has a "flat top knuckle", That will be a plus if you ever plan steering upgrades. 75 and earlier will have that.
  5. pplblazerdude
    Jul 18, 2002
    242
    I havent seen the axels the guy said they where out of a 70s 3/4 ton pickup. Is there a chance it would be a sf instead of a ff i dont wont to persue it if theres a chance. Also will a flat top knukle work with my stock steering. I dont wont to spend a bunch of money on the side.
    Clint
  6. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    If its 70's its a 14FF. Flat top knuckles have the same steering as yours( drag link on the driver side) Flat top knuckes are what is needed to do crossover steering, if you ever decide to go that way.
    4.10 is a good place to start. With 35's you will be just right for playin and using it as DD. I say grab them axles now, rebuild your motor when it quits runnin.
  7. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    The flat top knuckle will work with your stock steering. The reason he brought up the flat top knuckle is because you will need it if you want to go with crossover steering later on. /forums/images/graemlins/thumb.gif Here is ORD's stuff for crossover. You can read up on it here at ORD. /forums/images/graemlins/thumb.gif
    Rick
  8. pplblazerdude
    Jul 18, 2002
    242
    I cant wait much longer for the engine rebuild is i go through a gallon of antifreeze in less then 500 miles and 1 quart of oil every 500 to 1000 and i already have 4 10 in my blazer all i will get out of it is strength.
    CLint
  9. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    When you go to install these, allow plenty of time. If you are running 15" wheels, some amount of caliper grinding will be necessary. While not difficult, it is time consuming. Other than that, pretty much a straight forward swap. /forums/images/graemlins/thumb.gif
