How much lift before an angled arm is needed on a Dana 60 crossover conversion?
Discussion in 'The Garage' started by Sandman, Nov 11, 2002.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I am getting ready to do the crossover conversion and found the non angled arm and the angled arm. I run a 6" lift and could use my 3" steering block If needed. I found the arms here . What do you guys think?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I think you'll want the drop just to help the draglink clear the crossmember. </font color>
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    IIRC, the angled arm help the overall geometry of the x-over. A steering block would only bring the drag link closer to the crossmember, which would hit as soon as you are crossed up.
    I know that when you run the ORD X-over with ORD zero rates, even with the bent drag link, it will bind on a stock engine crossmemeber.
    I would get the angled armand be done with it.
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i was wondering the same thing----i have the straight arm and noticed when i went out last night i went through the total compression on both of my front shocks and and not a scratch on the arm or the crossmember. i am still going to so something about the crossmember. i just don like how it is so close to the arm.
    BTW i have a 6" TC EZ lift
    i wouldn't use the steering block if you can avoid it---i personally dont like all that leverage on that point.
  5. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks for the link. Thats the cheapest I've seen them. What did you do for a draglink? Looks like I'll go ahead with the angled arm.
  7. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Here is my whole set up:
    got reman steering box from Advance auto for $200 w/ $50 core (junk yards around here are crazy)
    got that steerng arm for $100 shipped
    got drag link from rock stomper for $135 with both tie rod ends (bent version) (minus $10 for CK5 member)
    then i called summit got a price on a dropped pitman arm for a i think a 78 F150, he said $69.99, I told him NTW had it listed in a magazine for $59.95. He looked it up and found it and sold the arm to me for $58.95 shipped w/ no handeling fee. I ended up spending around $434 for everything.
