how much lift do add-a-leafs actually raise the vehicle?
Discussion in 'The Garage' started by rocko, Nov 19, 2002.
  1. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    I've heard about 1-inch to 2 inches..
    What is everyone's experience.. I've got to get rid of the saggy butt on my Blazer..
    Or.. is this possible..
    Use 0RD zero rates with lift blocks? I know you aren't supposed to stack blocks.. but it's only a 2.5 inch block with the ord block..
    Yes or no? /forums/images/graemlins/thumb.gif
  2. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    I got 2 1/2" from front add a leaf. can't remember brand name but got then from summit
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i'll give you my add-a-leafs to try...i pulled them out because my front shocks finally flex down enough to make the truck level. the ride with them in was much rougher than i wanted.
  4. rocko
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Thanks Russ..
    Here's my plans..
    1. Add the zero rates to my 2.5 inch lift blocks in the rear
    2. Add Add-a-leafs and zero rate 1 inch block and remove the lift blocks.
    Which would you all recommend? I really will never wheel the truck.. what would be fine for street use.. and mild recreational offroading.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    #2 becouse the ORD Zero rate are not really blocks sence they bolt to the spring pack. They are in reality a add a leaf.
