How much lift do I need?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Kajun_K5, Sep 17, 2001.
  1. Kajun_K5
    Kajun_K5 Registered Member
    Jul 9, 2001
    48
    Lafayette, Louisiana
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Sure! You may want to do a little fender triming to make sure you won't rub. But that should fit for normal driving type stuff. If you plan on any type of trail rideing I would trim a bit...
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Also depends on the width of the tire...the offset of your rims....and if your rig has a body lift....
    C'moe
    <font color=black>the blazer is "Back in Black"
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I've heard a 6" lift and a 1" body lift should clear it, unless you do rocks and get real flexy.
    -- Mike
    <font color=blue> At some point I'll be done building my truck and can actually go wheeling. Until then, I guess sex and alcohol will have to do. [​IMG]
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I run a 6" and a 3" body lift. My 16x38 Swampers on 12 wide wheels seem to clear fine.
    I get all the exercise I need pushing my luck! [​IMG]
  6. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    4"
    I've got 4" and I"m running 36" swamps and have NO rubbing. I've trimmed a little, but I think it looks better. I can run 37's with no trouble now.
    Kyle
    89K5
  7. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    It better be, because that's what I'm planning. But then again, I just bought a Sawzall and I'm not afraid to use it! heheh
    I don't think so, therefore I'm probably not.
    http://photos.yahoo.com/dana60manual
  8. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    I run 38.5 by 14.5 with a 4" lift with NO rubbing with some fender trimming.
    350, sm465, NP205, 14ff w/detroit, yucky ten bolt 4" springs,38.5x14.5 swampers
    <a target="_blank" href=http://www.planettribes.com/theden/gontw/nsig.jpg>http://www.planettribes.com/theden/gontw/nsig.jpg</a>
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    What the hell, i have a 6in lift and 35x 12.50 i dont know what happened i thought i rubbedmy tires the other day i went down this real shallow ditch type thing and i heard grrr. i dont know wtf it was just assumed it was tire rub... but there still is alot of travel between the fender and the tire andi felxed alot w/out rubiing... duno what that sound was... anyway, yeah you can have trimmed fenders w/ a 4" lift and go 39"s easy.
    6in 87' K5 w/ 35" BFG muds.
    Kn filter
    What I need: 4.11 gears, Lim Slip Dif, Force2 Catback, rear springs , Throtle body spacer.
