How much lift does 52"...
Discussion in 'The Garage' started by Brocky, Aug 8, 2005.
  1. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    I was wondering about how much lift 52"s up front give you. Also is there a way of using longer shackles to add more height to it. And how much is too much. Also crossover steering, what do I need and where do I get it for the best deal? Any ideas?
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    52's up front give you 4" of lift. your going to need crossover and longer shocks and brake lines. check out ORD or SKY.
  3. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    so Is there a 2in lift 52 spring to get up about 6in with some flex?
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    rear blazer 2" lift springs
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yes, up front you should net about 6" w/ a 52" "rear" spring that has a 2" arch built in. The spring rate would be 405 lbs. (TC EZ ride) vs the 325 lbs of the popular TC EZ ride 4" 48" front springs. I believe that the extra length would make up for the somewhat firmer spring pack though... in reguards to flex. It would probably still flex very well, but still have some respectable road manners... I would think. At this point and time, it's what I plan to go with myself. It probably would not flex as nice as a stock no arch 52" pack, but then again, you will be stuck with a 4" lift. If you need more, then this is one option.
    Zero rate, body lift, lift shackles are other ways to net the difference.
    W/ X-over you will need a 2wd steering box, or make an adjustment to your current one. The rest can be bought from places like Off road disigns as well as others. Prices vary somewhat, but are roughly in the same ball park from what I've seen.
  6. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I'm gonna do the 52s this winter. However I'm gonna wait until Kidjethro fabs up a way to gain a few more inches with stock 52s then steal his design.:haha: He comes up with some of the coolest/nicest stuff.:bow: I'm running 6" springs in the front now and don't really want to loose the height I'm at but I could use more flex.
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    :D ;)
  8. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Damn, you busted me. :D
  9. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    I think that the 2" lift 52" tuff country springs are all most as soft as there 4" stock front springs when you take out the overload. I have run the 4" stock and the 2" lift 52"'s and they are extemely simmiliar in flex from what I have noticed. The 52"s flex allmost too much for the front I max out my 14" travel shocks. Having the shackle set up properly is key to them working well.
    Be prepared for a high angle front driveline, loooong brake lines, x-over, and properly placed shocks.
  10. Brocky
    May 22, 2005
    1,170
    Thanks guys. Geez you get all kinds of good info here. Maybe I should move closer to get away from the Jeep club I am in with a k5.
  11. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I got all my steering stuff from Trevor over at WFO Concepts
    I tried 2" lift 52's and wasn't happy with the height - they sat just too high.
    Here's how it sat with 2" 52's and a 3" body lift. Those are 38's. I think due to the increased arch of the 52's they provide another inch or so of lift when used up front.
    This is the same truck on stock 52's:
  12. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Jeeps are for girls :D
  13. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I think that would make a wonderful bumper sticker
  14. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Did you leave the overloads in or remove them?
  15. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I left the overloads in there for 2 reasons:
    1) Limit uptravel and see how they performed
    2) I was on a time crunch and didn't have time to remove it. It was t-minus 4 days before our major trail ride and I just needed them in and done! :)
    They seemed to perform very well. I wanna climb an RTI ramp before I make final judgement though.
    -Mike
  16. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    with the lifted 52's in front what'd you use in the rear to keep the truck level? or did you have it level. I just can't stand it when the front is higher than the rear so in my case I really want to get the ass end up a little more than the front.
  17. HillJackCustoms
    HillJackCustoms Registered Member
    Apr 19, 2005
    64
    Indiana
    Yeah i was curious myself.. I have an 8 inch lift and want 52 inch springs in the front... So would i just get a 4 inch lift kit for the 52 inch springs or what??... The 52 inch would include the blackwidow shackles... But what you think.. Should i just stay with the 8 inch lift and not do the 52 inch springs???
  18. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    4" lift springs, would give you ~9"+ realistically. They're arched more so the your shackle angle could be almost vertical which would lift the truck up a little more. If you adjust your shackle hangers to accomodate, you could end up with better shackle angle which would drop the truck back down closer to the 8" range.
    -Mike
  19. HillJackCustoms
    Apr 19, 2005
    64
    Indiana
    so your saying with the 52 inch springs up front, a 4 inch lift there and an 8 inch in the rear would be good
  20. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    that is my plans
