How much lift from the homade shackle flip?
Discussion in 'The Garage' started by howdiy, Apr 29, 2007.
  1. howdiy
    howdiy 1/2 ton status
    Jan 28, 2004
    3,309
    Fl
    I'm going to do the home-made shackle flip and I can't find where it says how many inches it's good for anywhere.
    http://coloradok5.com/shackleflip.shtml
  2. super k
    super k 1/2 ton status
    Dec 4, 2004
    209
    3
    Old Line State
    Are you asking what the suggested limit to this mod is?If you`re making it,than you can make it whatever you want,right?I see them in 2 and 4 inches lift.
  3. howdiy
    Jan 28, 2004
    3,309
    Fl
    No read the link
  4. howdiy
    Jan 28, 2004
    3,309
    Fl
    Does anyone know?
  5. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    when i did my home shackle filp. i just reused the stock shackles. i *belive* mine is somewheres around 4" i didnt measure beofre. i did it.
  6. ZooMad75
    ZooMad75 1/2 ton status Premium Member GMOTM Winner
    Apr 5, 2003
    999
    593
    Pueblo, CO
    Here's a really easy way to estimate the lift if you are going to cut a hole in the stock hanger. Go measure the length of the shackle (from the bolt in the hanger to the bolt to the spring) Now take that measurement and measure down from the bolt in the shackle at the spring hanger. It's not an exact measurement as your shackle probably won't be sitting straight up and down, but it will be in the ball park.
  7. howdiy
    Jan 28, 2004
    3,309
    Fl
    I guess I could always put a longer shackle on also.
  8. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    Remember, a 2" longer shackle results in (at most) 1" of lift. Less than that is usual, as your shackle isn't perfectly up and down.
  9. Scrt_Agent_Man
    Scrt_Agent_Man Registered Member
    Jan 13, 2007
    86
    Phoenix, AZ
    On my 89 we did that in the rear and a 5" spring up front and it still sits perfectly even.
  10. howdiy
    Jan 28, 2004
    3,309
    Fl
    Yep
  11. howdiy
    Jan 28, 2004
    3,309
    Fl
    Has anyone else done it?
  12. Scrt_Agent_Man
    Jan 13, 2007
    86
    Phoenix, AZ
    I'm planning on doing it on my 87 this weekend. If I get it done I'll let you know if I get any different results.
