how much lift is needed? to fit 38x12.50's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crossy, Oct 23, 2002.
  1. crossy
    crossy 1/2 ton status
    Jul 12, 2000
    257
    southern ,N.J.
    how much lift is needed? to fit 38x12.50\'s
    86 K5, just like the subject says, I'm not afraid to nip the bottom corners a bit. but give me the alternative of using cut out flares also. thanx , DAVE
  2. rogerwilco71
    rogerwilco71 1/2 ton status
    Sep 22, 2002
    179
    Central-Cal
    Re: how much lift is needed? to fit 38x12.50\'s
    8"= tight
    6"+3"body= Good
    10"=you're good forsure
    6"=you're cutting your fenders
    Most popular I've seen is teh 6"+3"body(economicaly)
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    ive got 4" suspension. im gettin new tires within the next two weeks and plan on eith 38" or 35" super swampers. i think ill prolly go 35" so i can leave the fenders in
    NITRO
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    mudhog has 38x12.50 on a 2.5". /forums/images/graemlins/pimp1.gif i would do it on a 6" with a 2" body, that'll probably be my ext setup.
  5. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Does anyone have any pics of 38X12.50 on a 9.75 rim? Swampers on their rig? I almost got a set but I thought that they would be a little skinny for the height. I am running a 9.75" rim, and am curious if anyone has any pics of this. Thanks /forums/images/graemlins/truck.gif
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    38x12.5x16 TSL on a 16x10 rim:
    Btw, that's 4" of lift and some cutting/removal. /forums/images/graemlins/eek.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    actually mine are 38x13x16in tsl swampers on 6.75in rims with 2.5in lift and lots of triming /forums/images/graemlins/smile.gif
  8. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    6.75s???? /forums/images/graemlins/eek.gif
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Here is a pic of my 76 on 40's with 5" front 6" rear. and broken/sagging body mounts. 76 on 40's
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    in my expereince, fenders are highly overrated /forums/images/graemlins/cool.gif /forums/images/graemlins/thumb.gif
  11. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Here is mine with 6" lift 2" body & fenders trimmed out w/ 38.5x14.50x15 TSL?SX's
    If you don't want to trim your fenders, then your gonna have to go higher with Spring lift.
    Bill
  12. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    ive got 6+3 and 38/15.5/15 radials. Its lifted pretty damn high Id say a 7-8 would do the trick. Oh well, just have to get bigger meats next time around.
  13. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yup 6.75 stock steel rims /forums/images/graemlins/smile.gif
  14. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I also use skinny wheels, why do we need the bead locks if we can squeeze the tire in a tight wheel that doesn't want the tire to pop. /forums/images/graemlins/thumb.gif
    Plus they're cheap. /forums/images/graemlins/thumb.gif
  15. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    The thing to remember when asking this question is, how are you gonna use this truck? I have 35's & 4"lift they don't rub on the highway, but if I was to disconnect the sway bar & try to flex it, goodbye fenders. My opinion is, if you're gonna wheel it: 6" lift= 33" tires. If you go 35's you will probably have some rubbing going on. On the street with 6" lift you could probably go up to 38 or so.
    Disclaimer: I have no actual experience with wheeling. My opinion is based solely on being a web wheeler /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif
