how much lift to clear...
Discussion in 'The Garage' started by tomford, Nov 12, 2006.
  1. tomford
    tomford 1/2 ton status Premium Member
    Jan 19, 2006
    921
    7
    New Hampshire
    36 inch super swampers? i have a 3 inch body lift and i think some suspension lift i have 33's on it now but im wondering if the'll fit with out fender trimming
    Tom Ford
  2. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
  3. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    everything depends on what you want to do with it. if you're going to wheel it - and you're really against cutting fenders, go w/ the 4" susp. and the body lift. if you're not actually going to wheel it, they'll fit just fine w/ the body lift.
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I had 35's with 10" of lift and no fender trimming and they would rub all the time when wheeling.
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    :confused: unless you're kidding you either had some ubelievable flex or a combination of that and some interesting back spacing on your wheels, i suppose.
  6. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    I had a 4" lift and 33s and would rub all the time.Dan
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    I ran 35-16.5/16.5 boggers on 12" rims under a 8" superlift. they rubbed when I would flex it. I ran bushwhacker cut-outs and even cut the inner fender liners up about a foot. the tires before didn't rub as bad, they were 35-12./15 on a 10" wheel under a 6" lift. backspacing and tire width play a big factor.
  8. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    keep the sway bar on and get a 4" suspension. unless your going to do some serious flexing, then get a 6" with the body lift.
  9. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I run 40's on 2" of lift, I dunno what all you guys need these massive suspension lifts for...:confused:
  10. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    my old 79 had 36" tsl's on stock rims and no lift. I cut the fenders and mini tubbed the rear and it fit no problem. Lots of work though but it wheeled better then the rig in my sig. Its all about the :hack: :grind: :weld: and anything can be done.
  11. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    my truck has 35/12.5"s and they rub all the time!! my blazer has 35/12.5" with no lift and i cant turn the wheels!!!LOL
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  13. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    time to get out the:hack: when i got my 89 i put on 35X12.5 and trimmed the front fenders just a little bit and wheeled it like that a few times, worked great.
  14. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    yup:D and :grind:
  15. mxfireman
    Dec 7, 2002
    2,480
    LHC, AZ
    47 million more times. Thats why I put up the same thread you did! Guess it wasn't worth the sticky!:haha:
  16. divorced
    Jul 20, 2004
    5,115
    Nope, nothing fancy here, just an old pile of junk :haha:
    It has about 9.5" of lift in these pics with some 38.5" Ground Hawgs that measure about 37". It had a 3" body lift with 6" front springs and a .5" zero-rate-type block. The shocks acted as limiting straps and the spring eye bottomed out against the frame on compression, otherwise it would have flexed more. You can see the front tire rubbing the fender with the tires turnde straight ahead. If I would turn the streering wheel, the tires would really eat the fenders.
  17. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    nice truck looks cool!
  18. divorced
    Jul 20, 2004
    5,115
    Thanks.
    It was a nice truck, but the frame got weak and cracked a few times, so I scrapped the truck.
    Here's a couple more randumb pics...
