how much lift to run 33x12.50s?
Discussion in 'The Garage' started by WantedaDodge, Jan 9, 2005.
  1. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    Will I need to lift to run 33x12.50s? I'd assume only a 2-2.5 inch lift? or will they fit stock?
    I have some 2.5 inch addaleaves for the front end of my old dodge. I knew you needed those to run 33s on dodges, but don't know about chevs...
    oh yea, body lifts suck!:grin:
  2. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    depending on tire with, spring rate, the answer is... maybe.
    I ran them for a couple years, it would only touch on full flex with the sway bar attached. If you disconnect the sway bar... I dunno. It would most likely touch. You can either trim the fenders a bit, or.. add a small lift.
    a 2" or 2.5" lift should clear those, but I dont know how good "add a leafs" are as a lift system. they might remove a lot of the flexing ability. Thats just my two cents.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    0" of lift, run narrow rims.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    :D :D :D
    They never stop, do they?
  5. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    coult cut the fenders up quite a bit and run 'em with no lift
  6. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    my 33" x 12.5"s hit my front only slightly when going over a bump w/ the wheels turned, so i trimed the inside of my front fenders a TINY bit like 2" max, didnt even have to touch the outter fender, and it was good, now i have a 4" lift and its even better. :)
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    6" lift. :) That is what I would go with, I loved the way mine looked with 33x14.50 SSR's and six inches of lift. You could get away with a 2.5" easy. Seems 4" and 33's are a very popular combo.
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I run 33x12.50's on 8" wheels w/ 2 1/2" lift on my burb (2 1/2" front springs, small block in the rear). I have no rubbing issues at all. A 2 1/2" lift is the easiest to do. No new drag link, relocate/re-route the stock brake lines, and no need to relocate the sway bar. I run Tuff-Country EZ rides. I like them, but I'll be swapping over to BDS soon.
    Remember to use all new u-bolts if you do a suspension lift.
  9. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    all depends on rim size and back spacing. my first set of 33's were on 8" rims w/ 4.5" backspacing. stock they touch going into driveways fast.w/ 3" liftthey'd scrub w/ the swaybar unlocked. when i got my mud tires(33" tsl's on 15x10" w/ 4.5 BS) they tore my fenders up. the bottom rear portion of the fender was peeled back. u ended up trimming it up to the inner fender and now all is good.
  10. big_black_blazer
    big_black_blazer 1/2 ton status
    Dec 19, 2004
    114
    Western Kentucky
    my 89 blazer sits stock with 33x12.50 yokohama mt's and only rub the inside fenders at full flex with the wheels cut lock to lock, or when i drive off of a curb fast enough to bounce it while cutting the wheels. the wheels are 15x10 stock steel "white spokes" off of a late 70's k5. just put 'em on and if they rub, put on a 2" lift from jc whitney for $300. after all, this has to be the cheapest (and easiest) truck ever to lift.
  11. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    im running 33x12.5r15 tsl's with no lift and the sway bar still on. the tires did all the triming that i needed. at full flex they do rub on the wheel wells but i still injoy wheeling it like that.. i would go with a 4 inch lift because u can allways cut the fenders a little to make room for bigger tires. thats the way im going.
  12. 89Silverado
    89Silverado Registered Member
    Dec 14, 2004
    6
    Connecticut
    My 89 has a 4" lift and 33-12.5-15's(Dunlop Mud Rovers), on 15x10 wheels.
    I have about 2" or so between the tire and the fender when i turn the wheel.
  13. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
    no smaller than 4". At full articulation, I get slight rubbing on drivers side fender.
