How much lift with home-made shackle flip
Discussion in 'The Garage' started by jakkedjimmy, Jul 17, 2006.
  1. jakkedjimmy
    jakkedjimmy Registered Member
    Feb 20, 2006
    17
    Springfield, MA
    How much lift does the shackle flip in the technical articles yield. Im guessing around 4?
  2. jakkedjimmy
    Feb 20, 2006
    17
    Springfield, MA
  3. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Yep, it's around 4". If you build your own, you can make it whatever you want.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i got about 3.5" with mine, using 64" springs
  5. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    A much betterer way is to use stock hangers. IE the ones at the front of your rear springs. Grimreaper, (name?) one of the mods, uses this. It's stronger than cutting a hole in the bottom of the stock rears, and you wont need to put any triangulation on the top. You should be able to get a set for next to nothing at the 'yard, who ever needs to replace those?? :p:
  6. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    thats the way I did it too. found some front hangers off the rear springs of a 2 wheel drive for $20. cleaned them and painted them. just make sure to get your measurements down. I screwed mine up and only got about 1" but soon Ill be changing a few things and Ill move em back to get between 3 and 4 inch so I can ditch the rear blocks.
  7. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Grimreaper welded his to the frame, he suggests using bolts. I agree, but I'm lazy and probably would have done the same. ;)
