how much lift without driveshaft mods?
Discussion in 'The Garage' started by Bigdawg234, Nov 18, 2006.
  1. Bigdawg234
    Bigdawg234 Registered Member
    Apr 11, 2006
    29
    Leechburg, PA
    I've always run longbed trucks. Now i've got a 1990 k5 blazer and i want to lift it. I was just wondering how high i can safeley go without the need for a modified shafts. I have a 4" skyjacker to go under it, but I'd like to go more(as in adding more springs or blocks) and as a side note it sits the same as stock and has no sag to it now.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Typically you can go 4" block or spring and not have to do any driveshaft mods. This however is only a starting point, the only true way to tell is lift it then see if it will still work.
  3. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    my 83 blazer w/ 6" procomp lift and 35" tires needed no driveshaft mods. and still drives and wheels fine, but a cv or fixed TC yoke would help.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i was running 8" lift with stock front shaft and had the rear lengthened 3" and it worked fine. 6" lift would be the most id run if you dont want to do driveshaft mods.
  5. Ronnie4wd
    Ronnie4wd 1/2 ton status GMOTM Winner
    Jun 4, 2002
    749
    Stockholm.Sweden
    With 6" lift I had to grind the ears off my front cv.
    Broke one to learn :doah:
  6. drop the hammer
    drop the hammer 1/2 ton status
    Feb 26, 2006
    160
    Massachusets
    I have an '83 K-5 with a 6 inch Rancho lift and 35in Mudders and the drive shaft has fallen out of it once already. Luckily I carey enough tools and spare fluids to put it back in. My slip yoke is hanging out pretty far and I am currently saving up to get a custon shaft made at the local axel and driveshaft shop.
  7. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    in the grand scheme of things, driveshaft mods aren't all that expensive. i wouldn't let that hold you back from drving the truck with the stance you want to. IMO
  8. Bigdawg234
    Apr 11, 2006
    29
    Leechburg, PA
    alright thanx guys, i think I'm gonna stick with a 4" for reliability, and the fact that i only got a set of 33" bfg muds for the winter. My truck gets all the goodies put on it, the blazer is just a little beater/daily driver, I also got front and rear hitches, and a brushgaurd so I'll post pis when I'm done
  9. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    6in. lift with stock shafts
    I think I need to fix it
  10. drop the hammer
    Feb 26, 2006
    160
    Massachusets
    Damn stick a set of white wheels on her and take the running boards off and you have a carbon copy of my truck. As well as the same driveshaft issues
