How much lift?
Discussion in 'The Garage' started by Kyle Strong, Nov 23, 2005.
  1. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    I am planning on throwing some 38in swamper tsl's on my 72 blazer. It has a 10blt front and 14bff rear, 3in body lift. I was thinking of getting an 8in lift, but can I get by with something smaller, or do I need to go bigger? Any pics would be awesome! :D
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    :hack: :hack: :grind: and you dont need any lift. :D
  3. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    that's a lot-o-sawing if you ask me... :laugh:
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    depends on wheeling. rock u need to be low. mud the higher the better. for rocks id say no more than 6" lift. mud id go with at least 6". trails depends. are u trying to keep it clean or are u going to try to make your sh*t fit through the jeep trails?
  5. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    I'm putting it through Jeep trails!! :D Mostly mud though, not many rocks, just normal trails
  6. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Swap the body lift for a 4-6" spring lift and bust out the sawz-all!! I know people use body lifts without problems, but have heard enough BAD stories that I will stay away from 'em. Then get some 4.88's and a locker or two.
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    do 4" springs in front, shackle flip in rear and get a 1" body lift from ORD. hack the fenders and fit those 38.5s! at least a detroit for the 14b. dont spend money on the 10b besides matching gears unless u dont plan on swappin for a 60 eventually.
  8. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    4" is enough lift for 38s. I have 5" and 39.5s. Sawzall any sheetmetal that gets in the way. Use a DIY shackle flip in the rear and your stock springs + a zero rate. In the front use BDS or TC 4" lift springs. Both are good and relatively inexpensive.
    4" is a good amount of lift IMO for more trail riding.
    j
  9. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    if i were you i'd stick to the 4"-5" lift with some hackin' if you have 4-5 and a 3" body you may not need that much
  10. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    I only thought I'd need around a 5in, but I was doing some reading and saw some people with 8in, so I was wondering. I need to invest in a sawzall though :blush:
  11. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    So what all goes into a shackle flip? And how long will the 10 blt stay together with 38's?
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    depends how you drive...ull be pushing its limits, so be careful.
  13. stano
    stano 1/2 ton status
    Jan 24, 2005
    130
    Iowa
    trails and only trails I think 2" lift. 2" lift is plenty for me and a little taller tire than stock maybe 33. I get angled side ways to much. I for one don't like high lifts on trails. Just a little higher than most vehicles and the lower vehicles will clean the trail out for the differential.
    Crawling is another thing.
    stano
    87 K5
  14. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I've got 38.5's, a high compression 383 stroker and a front 10 bolt. I have a very light foot though... I know 1 slip of the throttle at the wrong time and "POP" goes the 10 bolt.
    Since you already have a 3" BL I'd say go for 4" springs up front & a shackle flip in the back. A little hacking of the fenders and you'll clear.
    My tires clear at full flex with only minor :hack: :grind:
  15. Kyle Strong
    Sep 26, 2005
    280
    Eugene, OR
    As of now it's only trails, but that's because I haven't found too much mud lately. :mad: I have 33's now, but I still drag on stuff. I plan to mostly mud, and I have a heavy right foot, so I plan on upgrading to a d60, but not for a while/break the axle...and thankfully I don't care about cutting or body damage, so that's not a problem. The shackle flip looks like a bit of work though it's probably not...
