how much lighter is your 14 bolt.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, Jan 14, 2003.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    after you went from drum to disc? standard 14 bolt FF. has anyone measured the weight difference?
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I read somewhere that it is 70 lbs.
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Like POWERMAD says....around 70-75 lbs. lighter. /forums/images/graemlins/thumb.gif
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    That sounds about right for me also. /forums/images/graemlins/grin.gif
  5. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    doing work on mine before I hang it, I'm trying to lighten it up.I have it all apart and weighed all the parts.
    axle housing...187 lbs
    axle long.....17-1/4 lbs
    axle short....15 lbs
    hubs..........48 lbs
    drums.........77 lbs
    brake plates..44 lbs
    total.........389bs
    My numbers so far..
    axle....need to recheck after doing this(187)
    axle long.....17 lbs....gun drilling will change this
    axle short....14-3/4 ...gun drilling
    hubs..........35 lbs
    rotors........36-1/2 lbs
    calipers......31 lbs...brackets,pads,bolts
    total so far..321 lbs
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    wow, 389 so far, minus diff unit and gears and bearings and such ?
    damn
    those caliper brackets: are they made of perfectly flat steel stock ?
    thanks
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    the diff unit, gears and bearings are in the axle housing at 187 lbs....the caliper plates are ground flat...
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I think 70lbs is about right.. every little bit counts, and 70lbs is substantial in that game, especially on the axle!
  9. misfit
    Jul 21, 2000
    324
    tonyp, i like how you profiled your diff...
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Oh yeah. I think every bit counts. Since I put my Blazer on a diet, I have noticed a huge difference. I'm always looking for ways to shave the weight. (without going broke). /forums/images/graemlins/grin.gif
  11. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Curious... how did you lose 13 lbs on the hubs? That's quite a bit.
  12. TONYP
    Aug 13, 2002
    2,116
    so cal
    I had to turn the outside dia of the hub to allow my 6 lug rim to fit over it, then I cut the inside of the hub(where the drum sits) to move my rotors into the rim more....if you can see in the pic I also cleaned the inside bolt pattern of the hub up, it had a big chunk of steel between two of the holes where the mold gate was....
  13. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    I'm curious, what did you turn the outside of the hub down to? I'm trying to figure out how small I can go without worrying about anything. I was planning on 4.125".
    What rotor did you use?
    I want to use a plain-jane 10 bolt 6 lug rotor but I think I might end up using a IFS rotor because it has a hole in the middle that is bigger. I'm trying to find a no-brainer solution that doesn't require machining rotors each time I do a brake job. I'd really like to make it so I had the same disks, calipers, and pads front and rear but I don't know if I'm going to be able to pull it off.
  14. TONYP
    Aug 13, 2002
    2,116
    so cal
    your hole size is right, the hub is so thick out there it will change very little, remember that you will have to turn down your axle flange too. The rotors I used are 8 lug and I have the info at home on what there from(will get that for you tonight).They were only 1.225" wide, I had to find a thin rotor to fit the ford calipers I'm using, but they are thinner then the chevy rotors guys are getting.
  15. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    In the middle of my disc conversion now. Has anybody crossdrilled these discs? Thought it would look pretty trick plus a little less weight and cool better. Is this something that can be done without causing any problems anywhere else? None that I can think of but Maybe I'm missing something... /forums/images/graemlins/smirk.gif
  16. wrathORC
    Apr 27, 2002
    908
    Hancock, MI
    Yeah, they're pretty thick and I didn't think they'd miss 3/8" of steel but I was really hoping to get it down to 4".. but I think I might be pushing it.
    Do you think a 10 bolt/Dana 44 6 lug rotor would fit? I can't remember how big of a hole is in the rotors, I just remember it was bigger than the 3.5" hub diameter. I'm kind of worried about machining the backside of the hubs down too small.
    It kind of sucks that I don't have any of that stuff here. It's all 500 miles away.
    EDIT:
    wrong button...
    By any chance did you use late seventies F350 rotors?
    Thanks for the info.
  17. TONYP
    Aug 13, 2002
    2,116
    so cal
    I turned the hubs down to 4.250", thats the size of the hole in my 6 lug rim.
    If you put that rotor on it only has 6 lugs, so you would need some kind of ring or something to hold it on.
    I have my hugs here, I'll take a look at how thick the back side is......
  18. TONYP
    Aug 13, 2002
    2,116
    so cal
    cybrfire,
    be carefull drilling rotors as some are pressed together, solid rotors are crossed drilled, but vented rotors are vented to cool. I've seen rotors with cuts on the sides so you could look at it and see the bolts.....
  19. misfit
    Jul 21, 2000
    324
    i still have 14 bolt disc brake brackets for sale. pm me or go to my sig
  20. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    is that a stock diff cover? it looks like you wouldn't have the same problem i did when my spider gears shot through my diff cover and leaked diff oil all over my driveway, and for over a month now i've ben trying to get rid of the massive oil slick in it.
    i drove 5 miles home, AFTER i broke the spider gears, yet only 4 feet into my driveway did the gears get shot through the cover, so al 5 quarts or however much were in my driveway. that truck hates me.
    if that's not a stock cover, where'd you get it?
