how much money do you think a junk yard would give me?
Discussion in 'The Garage' started by bryguy00b, Jan 4, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    for these two blazers..the 84 runs and moves..and i think everything is in good workable order..and they both have good hoods/caps...
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Around here they only give you 50 bucks per vehicle.... /forums/images/graemlins/smirk.gif
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Same here. Might have better luck just putting an add in the paper.
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    good greif...and then i suppose they charge like 200 bucks for a transmision that someone comes and buys of it after they got it! /forums/images/graemlins/rolleyes.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    At least!!! /forums/images/graemlins/angryfire.gif
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    BTW, call a yard and ask how much a front or rear 10-bolt axle costs. Most yards get $500-600 for one. /forums/images/graemlins/shocked.gif
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/deal.gif
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    They sure do! It was almost cheaper to convert to 3/4 ton.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Thats right! Most yards pay very minimal, if not anything, for vehicles, running or not.
    And yes, they turn around and sell everything back out for outrageous prices, most of the time without warranties. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    I always like to haggle with the seller to get prices down. Even when he won't budge, I simply tell him that I've found another whatever-part at the other yard and want to see if this yard can beat their prices.
    I once got a yard seller to go from $750 for a complete D60 down to $500 even. Told him the gear ratio (3.73) was wrong and how much it was gonna run me to buy new gears, etc. /forums/images/graemlins/thumb.gif
  10. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    Here in Gladwin, they would tell you that they will haul them away and not charge you for it /forums/images/graemlins/shocked.gif. I would say you are defintely better off to try and sell them outright.
  11. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    anything that runs and moves regardless of how the body looks you should be able to sell it to someone locally instead of the J.Y. for at least 500 dollars or more.
  12. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    You should part them out.
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i think im going toi put an add in the swap sheet..
  14. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I wish I could buy them from you! I can always use parts. If you decide to part them out, let me know. I have a list of stuff from the one with gray interior i need!
  15. unclfstr
    unclfstr Registered Member
    Dec 15, 2002
    5
    Upstate, NY
    I'm interested in the Trans, if its a 700r4. I live off exit 27 of the thru way.
    /forums/images/graemlins/burb.gif
  16. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    OK, if you do part them out, I could use a Q-jet carb if it is in good working order.
    Thanks,
    Chris
