How much oil in a 454?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Nov 19, 2001.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I was told by the previous owner of my 454 that it uses two gallons of oil [​IMG]. Is this true?
    I'm asking this because A) I have to buy it beforehand and B) because it didn't include a dipstick I bought a new one, but I'm not sure how deep I should install it.
    It has a standard pan, no fancy stuff. The engine has 2 main bolts and is from a 1979 dually tow truck.
    Thanks.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Two gallons would make 8 quarts.
    Most stock pans hold 6 quarts.
    When I change the oil in mine, I only put 5 quarts back in since the 1 quart is still in the motor.
    So, with that 454 you are looking at, it's possible the guy was telling you the truth. He may have gotten the 7 quart pan. These 7 quart pans are available thru the aftermarket.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    What about adding oil until it shows correctly on the dip stick? Just a smart @ss idea! [​IMG]
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  4. Blazer79
    1,816
    Can something go wrong if too much oil is added?
  5. I am not absolutely sure, but I believe too much oil can hurt an engine just as bad as not enough. Something to due with oil pump failure and bearing life. Also I think you can end up with oil in the combustion chamber as well.
    American by birth, Marine by the grace of God
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, put in too much oil and the crankshaft will be whipping the oil into a froth. [​IMG]
