How much play in 208 output shaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by smack, Jan 17, 2003.
  1. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    I seemed to have developed vibration problems again.
    While changing u-joints I noticed that if I grab the drive shaft at the output yoke from the 208 I can jostle it up and down a fair amount.
    Anyone know how much play there should be??
    I've heard there's a bushing that can be replaced in the 208. Could this cause this play? Can it be replaced without pulling the case or fully rebuilding??
    TIA
    smack
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I have that same described amount of play and little to no vibrations...I think that play you feel may be between the splines on the d-shaft and the output t-case shaft. Also if you notice, atleast on mine when I do that the whole t-case kind of flexes up a bit....not much but some....
  3. smack
    Feb 24, 2000
    277
    Colorado
    How would I know if that bearing/bushing thingy inside is about to toast?? Or should I not worry about it?
