How much play in a steering box?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ascuro, Aug 25, 2006.
  1. ascuro
    ascuro Registered Member
    Sep 19, 2005
    62
    SoCal
    My steering's still a little loose on the road...got new balljoints, bearings, DLE's, TRE's. No play in the rag joint or shaft - the only thing I can find is some play in the steering box.
    I can turn the shaft just under 1/8th of a turn before seeing any movement on the pitman arm. Is that within specs? I can't find any guidelines.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    1/8" isn't all that much. If you do decide to tighten the slop with the set screw on top of the box just be carful not to trun it too much. I have read if it's two tight it will heat up real fast...
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Burt, he said "I can turn the shaft just under 1/8th of a turn" not an 1/8".
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    My 70 manual box is the same way. That little bit of slack actually helps when wheeling, takes some of the "snap" out of the steering wheel when going over rocks.
    By the book, adjusting the box preload requires a torque wrench set at like 10 ft lbs. For 30 years I've been doing it by feel and haven't trashed a box yet.
    Jack the whole front end up in the air. Tires can stay on.
    Back off the jam nut and turn the prelaod screw in bout 1/2 a turn.
    Turn the wheels lock to lock a couple of times.
    Repeat turning the screw in and turning wheels.
    When you can feel the steering tighten up when turning to center, then you are just a little too tight. Back the screw off a bit and tighten the jamnut.
