How much play should the rear output on a 205 have?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SCOOBYDANNN, Sep 14, 2006.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I think I found my vib problem but need some info.
    I get a very bad grinding noise from right under my butt so I think its definately the TC. It only happens at speed when I let off the gas. I tightened down the rear output yoke and I can move the output in and out about 1/2" is this normal
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    When I read that you had the 205 grind I was going to suggest that you probably need a cv rear driveshaft. IIRC, the output on a 205 shouldn't have any play. That sounds like your problem to me.
