how much por-15 do I need?
Discussion in 'The Garage' started by adamforsythe, Apr 5, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Well after doing a search and reading about por-15. I think I will use it. Now how much do you think I will need to do my frame, underside of my floor pan, and underside of my body?
    Do you think 2 Quarts should set me up?
    Pint = 50 sq. ft.
    Quart = 96 sq. ft.
    Gallon = 350 sq. ft.
    Adam
  2. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    Brush or spray??
    It goes a long way by brushing it--but spraying takes a lot more..I did the floors of 2 chevy trucks with a pint brushing it on,but a quart failed to do a frame by spraying it--2 qts MIGHT be enough if you brush it on,but if you run out and buy another quart,its almost the same price as a gallon..
    Its best not to "overbuy" POR-15,as its hard to store without it hardening up in the can--saran wrap under the lid works good to keep the lid from welding itself to the can..
    If you go to the swap meet in Hollis NH last sunday of the month,a POR-15 dealer usually sets up there and has decent prices--not sure how far away you are in maine,but its usually cheaper at the swap meet,and no shipping charge--plus a lot of parts to drool over too... :laugh:
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    I think I wil buy 2 QUART and if I need to I will order a pint if I run out.
    It should not take to much to do this.
    Adam
  4. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    Like Diesel4me said, if you are gonna brush it on it goes along ways. I would think that 2quarts will be enough. I also put saran wrap under the lid for storage and then i put on the little black clips that came on the cans since sometimes the lid will slowly creep back up without them and harden the paint. And like I said earlier, be sure to cover up all skin since this stuff is imposible to get off, takes a couple weeks at least, it will even soak right through tshirts and thin gloves and such and get on your skin!
  5. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    just a note to everyone on storing POR15...
    we use gallons of it at work.. we've tried all the tricks, saran wrap, etc... what works by far the best is if you take a few minutes with a paper towel and lacquer thinner and clean the lip out thoroughly and the edge of the lid.. it will keep way longer that way...
    and for the original poster.... 2 qrts brushed, goes a long way... and yeah, wear surgical gloves... ;)
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Some guy on here (vendor) offers por15 discount to ck5 members.
    I bought POR 15 several times- with our trucks, you kinda always need to have some on hand. I've kept POR 15 in the fridge for a year after using without any ill effects. I do however, recommend for the amount your doing that you get at least a quart, and use a cup/some other intermediate unit to dip from. You dont want to contaminate the whole can. They say even one drop of water can ruin it. Also, have several cheap brushes on hand- It seems that the POR starts drying up rather quickly as you apprach the end, and the brush will get just as stiff!
    (Dont forget to use some marine clean to remove grease, and metal ready to prep the surface)
