How much power or torque can a 208 T/C take
Discussion in 'The Garage' started by MEGALADON, Oct 24, 2005.
  1. MEGALADON
    MEGALADON 1/2 ton status
    Feb 4, 2005
    214
    HOUSTON
    I was thinking of putting a 770 carb and a strong cam in my 82 GMC,
    and started thinking it might not be a good idea with stock drivetrain.
    its a 454 with a 700r-4. I know most here will say the trans will go first,
    but lets PRETEND its a built 700r-4 for now :D
    If I'm correct, the 208 is chain driven.
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    The major weakness of the 208 case isnt really the internals, it's due to the fact that its an aluminum case. Without a skid plate, one hit on a rock and its dead. But a 454 with cam and whatnot shouldnt blow it up if it is properly maintained.
    -Harrison
  3. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    How do I find out where I can get rebuild kits??? :thumb:
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Google it
  5. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    I got my full rebuild kit along with a chain from Rockland Standard Gear. Top quality parts...
    http://www.rsgear.com/
  6. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    thanks, I can get the rebuild kit and a chain for a little over $210.00
    sounds like a great price to me. :waytogo:
  7. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Other than the case is a 208 as strong as a 205?
  8. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Not even close.
  9. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    how so?
  10. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    205's are gear to gear, and 208's are chain driven.
  11. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    But you will get a lower stock gear from the 208.
  12. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    But for what most of us are doing a 208 is OK...and 205s are HEAVY...weight breaks parts and impedes forward motion :D I have a NP241 (aluminum chain driven) in my cummins diesel dodge. I once tried to pull a large fallen oak tree off a paved road. i spun all four tires on pavement and didn't budge the tree. 430 lb/ft multiplied by whatever in the trans. I've aired out the truck, pulled trees down, dragged junk cars out of the desert, pulled stuck/broken motor homes at Pismo beach, and generally used it hard...no probelms with the case, just the front axle. Piece of crap fake 60...sorry, that got longer than I intended it to. :D
  13. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    Thanks for that info.
  14. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got a 208 and haent had any problems really, it jus has a little keak. i replaced the seal but it still leaks a tiny bit. im lookin to go 241 then sye in the future
  15. MEGALADON
    Feb 4, 2005
    214
    HOUSTON
    I did not plan on using my truck for crawlin or major offroad, just
    as a DD and some beach time, I wanted to make sure the motor
    would not over power the T/C and break it. :thumb:
