how much pressure on the coolent system?
Discussion in 'The Garage' started by LKJR, Aug 27, 2002.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Ok so I"m designing this on board shower system for my truck, do I need to worry about the coolent lines to/from the engine / heater core? or will the system pressure just force the water up?
    Click here for an idea of the design
    gonna do kind of the same thing just a little different, and gonna mount it off the pass frame rail offset to the fender a little just want to make sure the water will flow where it needs to
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I don’t think that I understand your question. That thing is a heat exchanger. You would plumb it into your heater hose on one circuit. Put fresh water through the other circuit. It’s a very good idea and there are even kits for it.
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    question is...do I have to worry about the pluming to and from the engine/ heater core, will the pressure push the water uphill? as in straight up
    framerail up to the heatercore
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Oh I see. I think it will be fine. People mount their radiators in the back sometimes and I've never heard of water flow problems. If it doesnt work for some reason, I guess your heater would not be very warm. But I think it would be fine.
