How much PSI when towing?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Jan 24, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    What PSI shoud I run when towing a horse a trailer which all together is about 5,000 pounds? I am running 33's
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>The darker side of nonsense...</a>
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I can hit about 35-36 psi max--but I guess you're probably talking tire pressure. [​IMG] I'd say probably max pressure for the tire (around 35 psi?). 15" wheels?
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    Yea...33/12.5R15
    Eric
    from Freekmont,CA.
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'd run 35psi if thats max... If you can go higher I'd run about 45-50. Remember, You'll need 10-15% tongue weight. roughly 500-700lbs. Be careful, thats a lot of weight on the tail end of a K5.
    When in doubt, slow down, esp with a trailer. I'd also make sure your trailer brakes are working.
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
