how much should a front 3/4 ton 10 bolt costs?
Discussion in 'The Garage' started by WantedaDodge, Oct 17, 2005.
  1. WantedaDodge
    WantedaDodge 1/2 ton status
    Dec 16, 2004
    282
    Eugene, OR
    I can't find one here for under $600!
    I have a full float dana 60 out of a dodge with 4.11s that I got for damn near free so I decided to put 3/4 ton running gear in my '84 Blazer. All I need is a front axle but I can't find a front end at any wrecking yard for a reasonable price.
    What type of money should they be hub to hub?
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if ur 10b is in good condition then just buy the 8lug parts and convert. all teh parts for the swap shouldnt cost more than $150 + shipping
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Yeah, swap the outers if the rest of the axle is good.
  4. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Just buy two 3/4 ton hubs and rotors from your local parts store for say a 79 K20 and then all you need is the caliper mounting backing plate and whala!!. Your old bearings will also work since the races should already be in the new hubs. But know is a good time to get knew one plus new outer axle seals as well. Your 1/2 ton calipers will also work.
  5. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    really, so that just means I just gotta get some 4.10s in there... Sweet! I thought the axle have heavier u joints or something.
    I just became a real member, is there a tech section with all the parts listed necessary for this conversion?
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
  7. WantedaDodge
    Dec 16, 2004
    282
    Eugene, OR
    yea, I pmed him...
    If I could get one with 4.10s in it, it would make it worth it, gears are gonna cost me $150 and I can't set them up myself.
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    personally i think thats alittle high though....i wouldn't go much higher than the $150-$175 mark
