How much $ should I expect to pay to have my rear diff rebuilt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Piranha300, Feb 20, 2002.
  1. Piranha300
    Piranha300 Registered Member
    Jul 1, 2001
    45
    Nebraska
    I have a 91 k5. Thanks in advance.
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    good think you didn't ask how much to have your rearend rebuilt cuz that would sound like a personal problem...
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  3. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    The going rate around here (AZ) is $250 per axle in labor
    Plus the cost of gears, you were thinking of re-gearing as well right?
    That is just differential work, gears, inner bearings, etc...
    If you want a drum-to-drum rebuild that could cost around $1000 per axle
    Chris
    "Whatever happened to my Rock N Roll?"
    IM nOt wEiRd, i jUsT lOvE tHe sHiFt kEy!!
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    A few years ago my rearend went. Actually the the Govlock exploded, and my dad had to get the rearend rebuilt. With a new Auburn Limited Slip it cost about $1000.
    My Chevy isn't broken, its just out of gas.
  5. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Put a re-man stock under my 91 sub about 18 months ago.. $1000K, over the counter. Some assembly required! (let alone the 250 mile round trip to fetch it!)
  6. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    Bet you had fun lifting the axle over the counter [​IMG]
  7. woody9
    May 27, 2001
    602
    Howell, MI
    Naw, that one was cake compared to the 14FF!! (ROFL)!
  8. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Here in The tall corn state the lowest quote for labor on setting up the r&amp;p I have found is $250 and as high as $800. If you are doing a 14FF they are easy, I am doing mine, but the ones that use carrier shims and pinions shims suck. I figured $150 for a 12 ton shop press and $100 for the pinion depth tool..there is the cost in labor alone.
