How much should I expect to pay...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Nov 21, 2001.
  1. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    I am looking to do a shock upgrade like the UAVs...question: how much should I expect to pay someone to fab me one of those between-the-frame-rail crossmembers that the top of the rear shocks mount to, and to mod the existing mounts on the axels? Both informed estimatations and wild guesses are appreciated! ;)
    J
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    HEY another North West CK5'er.[​IMG]
    I got all my metal for free, just had to buy the spring perches. I have $17 into it and about that for the 4 grade 8 bolts, washers and nuts. If you went to a shop you are looking at $45 per hour at the very least for labor. You are looking at a 4 hour job, or so depending on what kinda brackets and mounts you use. If the shop has done them before then it would be quicker. I would make a guess of $150 to $200 for parts and labor.
    Do you know of anyone that can weld? What shocks you running or gonna run? I could make you some brackets and make you a sweet deal, The crossmember could bolt in but the axel mounts have to be welded.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Try www.missourioffroadoutfitters.com Im not familiar with the shock mount on UAV, but I believe they sell what youre looking for.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Hey Jeremy, are you interested in fabbing one of those up? Might be able to 'hire' you to build one for me...............my truck has a clearance issue with Steve Frisbie's because my fuel pump is mounted in the frame rail by the 'top' of the frame as it goes up..........if you know what I mean. PIcs on my site of the pump location.............what do you think?
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  5. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Frank, I looked over you pics of the fuel pump location and I could make one that bolts to the bottom of the frame rail. If the pump sits back far enough in the frame I could use some c-channel and bolt to the top and bottom of the frame. for the axel mount I would just use angle iron with a shock stud. Let me know if you are interested, I would be glad to build you one.
    55 Willy's
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Jeremy,
    always good to hear from someone in the NW...I dunno what the rest of the country is doing, but we have some sweet rigs out here. =p The guy that won the top truck challenge (big burb) was from vancouver, WA after all. ;) Anyway...
    Unfortunately I dont have any buddies that weld. =( I want to run ProComp 3000 extended travel shocks (13.5" of travel). If you could hook me up with a good deal on the crossmember for this, that'd be sweet!! I am gonna do the shock upgrade when I swap in the ff14b, which will prolly happen early this spring....and if I had the hardware ready to do it, it'd go faster (at a welder-buddies pad or in the shop, either way). Any-who, how much would ya need and what measurements would you require?
    Jason
  7. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Hey Jekbrown, How much for your 10 blt ff after you get
    your 14 blt ff?-Jim
    88 5.7 5in lift 35"procomp at's
    700-208-456-3in exh w/flowlowder 10 bolts & some ORD stuff
  8. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    You could also talk to Rene, aka tRusty...he's DEFINITELY not afraid to make a little road-trip! FIRST-CLASS welder-fitter! He's in BC..not far at all.
    9/11/01..Never forget...Never forgive
  9. EDdaTREE
    Feb 18, 2000
    1,253
    Austintown, OHIO
  10. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    My father-in-law lives in Beaverton. He could store it for me
    till I could pick it up next vacation or untill I move up there.
    I would like to move to maybe the Gresham area. I put in some
    apps but got no replies. Strange I thought...Jim
  11. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I sent a PM
    55 Willy's
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
  13. JIM88K5
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Got it... thanks
    Jim
