How much slip is good for a fixed yoke?
Discussion in 'The Garage' started by neverendingproject, Apr 28, 2007.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    On my rear driveshaft, I have about 2 inches or so for it to slip out and an inch and a half for it to slip in. I have a shakle flip in the rear, and I dont know how much the driveshaft would pull out if I was flexed. I would think it would slip out further than in. So do I need it lenghtened?
  2. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    489
    Grand Rapids area
    All I have to say is that this is a quick geometry exercise. Assume that droop is limited by your shocks and stuff is limited by the bump stops. Then calculate the difference in driveshaft length.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    you should be fine
  5. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Thanks.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    the pinion is in the center of the axle so there wont be that much slip needed during alot of compression/ extension compared to an offset axle (like the front).
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    muddybuddy is right I have quite a bit of travel and still run the stock slip in the back, I think I only have like and inch showing and don't even use all of that, if you jump it and both sides compress you may need to do some figuring but I haven't ever purposly jumped mine. :rolleyes:
