How much spline contact needed in a drive shaft slip yoke?
Discussion in 'OffRoad Design' started by Eric M., Nov 23, 2002.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Any idea how much spline contact you need on the drive shaft to a 241C transfer case? I lost about 1" in the slip yoke after installing a 14 Bolt Full Floater. I've got 2 3/4" spline contact when the truck sits loaded and 2 1/2" with the suspension fully extended. Should I have the drive shaft lengthened?
    Thanks,
    Eric M.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Torque wise, you have plenty of engagement, for alignment, you can never have too much but you're probably fine. Before you have that shaft worked on, I'd make sure you don't need a CV or something.
  3. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Thanks. I should be fine as far as a CV is concerned, stock suspension, no lift and after about 2 hours of driving, no vibration. I won't be needing to do any work on the shaft, just keep the stock one as it is. I get to save a little money this time!
    Eric M.
