how much time for sas swap
Discussion in '1992-Present Chevy & GMC models' started by highlow, Feb 14, 2007.
  1. highlow
    highlow 1/2 ton status
    Oct 8, 2002
    124
    I am planning on having my truck converted to a solid axle soon, but I need to know roughly how many hours does this take to do? Has anyone had a shop do this for them and remember how long it took? Any help would be appreciated, thanks.
  2. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    as a person who installs stuff like this and works at a auto shop. its hard to say. every ride is diffrent when it comes down to this stuff. every time i do a new to me kit it takes longer than book time. but then i can do them no probleems after that .
    you need to find a good quality shhop and one that has done this kind of kit swap before. or you will end up over budget and with problems. a sas is not a super easy bolt on kit. every sas is a little diffrent. make sure you get a quality kit for your needs. and also dont forget driveline work and the need for crossover steering minimum.
    and you will need a drivers drop frt axle if you have a 4x4 to start with. if not then plan on a tranny tail shaft swap or rebuild at same time unless you find a used good 4x4 setup. or you could look for a divorced 205 case and run that behind the 2x4 tranny. this would help with driveline angles also as its mounted farther back for a longer driveline.
    so in all its a major build project to under take. but if you have found the need for sas on the ifs truck style its worth it in the long run for sure. dont forget most kits add min 3" over the lift spring specs ex: 4" lift springs + sas kit = 7 lift. it adds up quickly.
  3. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
    ill let you know in about a month :wink1:
  4. highlow
    Oct 8, 2002
    124
    Hey it's been a month
  5. Cajun4x4
    Oct 17, 2005
    889
    Lafayette, LA
    for the front i started at like 4 pm on friday and the truck was driving and all the tools where picked up at 6 pm saturday... the rear swap took about the same amount of time with the bed pulling, spring perch welding, shackle flip redrilling and all that mess
    id rather do 2-3 SASs rather than 1 ifs lift install IMHO
