How much to grind?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nofeartruckin00, Nov 9, 2001.
  1. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    I have a 14FF and dana 44 on the way, and wanted to know how much i should grind off the caliper to make 15" rims fit. I have read a few of the past posts, and the tech that steve fox did, and it sounds like the rim can just barley clear the caliper, is that right, so there is just enough clearance between the rim and caliper? How much is enough? Thanks.
    Got Dirt?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Do a search.
    Tim
  3. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Look at my tech article on the tech page. I included pics of the clearance. Basically you have to grind quite a bit. You'll take the rim and test fit, grind, then test fit it, then grind again. Keep on doing that until you can tighten the lugs all the way down and not have the rim rubbing against the backing plate or caliper. If you have any questions you can email me at waxer@rockreadyk5.com. I assume this is a 8 lug D44 you are referring to as the 6 lug will fit 15" wheels just fine w/o grinding.
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  4. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    When you are test fitting the wheels, paint the caliper &amp; backing plate reinstall the wheel rotate the wheel . And see where the paint is rubbed off , and grind some more. Repete until their is no interferance. That is how I did mine . It saves alot of guessing where to grind. Hope this helps.
    Later Ed
    Get use to the view.
    Because, if your not the LEAD DOG the view never changes.
  5. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Notice how he says WHEEL. don't try to do this with a tire mounted on that wheel or you we regret it and feel it the next day.[​IMG]
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Ah come on Esteban.. You can *Cartman voice* "Get all BUFF and be on tv... BEEFCAKE!!!" [​IMG] LOL
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  7. nofeartruckin00
    Oct 5, 2001
    798
    yeah, its a 8lug dana 44. thanks for the help, ill check the tech article.
    Got Dirt?
  8. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    Yeah it really sucks when there's a 36" TSL swamper mounted on the 'test rim'...[​IMG] I damn near died after mounting that thing on my truck for the 387th time. At least there's 8 lug nuts to spin on and off though...[​IMG]
    Rene...still tired![​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
