how much to install a lift?
Discussion in 'The Garage' started by bigoltrux77, Oct 11, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    Im planning on ordering a Skyjacker 8" fll spring lift kit through the tire company i work for (Discount Tire, i get factory price woo!) Its gonna run ma about 5-600 bucks. How much will a shop (4wheelparts etc) charge me to install it? What else do i need to invest in? I know i need to lenghthen the driveshafts, drop the transfer case, and lenghten brake lines etc. Who does all that stuff and what will it all run me? Will 35x16x15 Boggers look good on 15x14 rims and 8" lift? or will it look dumb. thanks alot. /forums/images/graemlins/k5.gif
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    the fact that you are thinking of taking it to 4WPWeirdo's after all the flack they get from everyone worries me. I would do it yourself. If you are running the stock running gear, it is a matter of time more than anything. the driveshafts will have to be redone, same with brakelines, etc. Instead of dropping the t-case, just get a CV 1-ton rear shaft from Jess.
    and i gotta ask, why lift? other ppl on this board fit 35's with zero lift, others fit 40's with a 3" lift.
    a sawzall costs $110 /forums/images/graemlins/thumb.gif
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I think it sounds like too much lift for 35's.
    BTW, I'm sending you a PM about something related.
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    With the 16" wide tires your need that lift and maybe more. Axles should be upgraded to 1 ton if you haven't aready with that size of lift and tire. May also want to look into a cross over steering, Disk rear brakes. Lot's of $$$$$
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I might be alittle strange, but I like the space between the tires and the wheel wells. I like the way it looks. Big tires and bigger lifts looks kewl in my opinion.
