How much $ to "tweak&peak"
Discussion in 'Communication (CB | GPS | HAM)' started by stephan van leir, Aug 27, 2000.
  1. stephan van leir
    stephan van leir 1/2 ton status
    May 4, 2000
    181
    central Colorado
    How much $ to \"tweak&peak\"
    Like the title says, how much should I be paying to get my CB tweaked. The local radio shop wants $55 to "tune it". I think that they are trying to gouge me because I said that I wanted it to be maxed. He got sh!++y with me after I said that. What do you think? Maybe someone knows a shop in Colorado that they can recomend?
  2. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Re: How much $ to \"tweak&peak\"
    I used to work at a shop, DALWORTH CB AND CAR STEREO about five years ago and my techs used to charge between 30 and 70 bucks depending on the amount of time put into the peak and tune.b
  3. Re: How much $ to \"tweak&peak\"
    It depends on the radio but it probably wont help much
    legal power is 5 watts for u 2 get a 1db gain you have to multiply the power by 4 or 20 watts . 1db amounts to someone listineng to the radio and being able to tell it just got a little louder . and it continues for 2db gain you will need 20 x4 or 80 watts . stock radios even when turned up max might give you 8 to 12 watts not enough for 1db gain and will shorten the life of the radio . your best bet is to get a small linear amp . again in a 20 or 80 watt power level .that way if the amp fails you still have a working radio at less power instead of nothing . yes you can go higher in power but after 80 watts it starts getting exspensive , power consumption on the vehicle goes up considerably , and usally the person that hears you doesn't have the same power to get back to you .amps usally a dollar a watt . mark359@earthlink.net
  4. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I just got a new radio and had it tuned. $12!!!This man has been doing it for years. I watched him do it and he had my Uniden at 35 watts and clear. Then i added the amp and it dead keyed at 200 watts.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You'd be much better off to find a local guy that works on them out of his house. Shops will way over charge !!! If you want to be louder, don't worrie about upping the watts, what you want to increase is the modulation !!!!!!!!!!! Put some swing in that thing, thats where it's at !!!!!
  6. Phreak480
    Phreak480 Registered Member
    Dec 13, 2002
    36
    dix hills, ny
    i do cb work on the side and charge no more than $20 to tweak n peak a radio
    also do all kinds of other work
    my big thing lately is clear top covers for cb's and illuminating the internals
    also i fix quite a few radios that were plugged in backwards, it's just a simple diods 99% of the time, that si if teh fuse ddin't blow (if the fuse didn't blow it's cause u did liek me n bypassed it, oops)
  7. chevblazk5
    chevblazk5 1/2 ton status Premium Member
    Mar 19, 2002
    257
    Sayreville, NJ
    Want to fix my radio?
  8. Phreak480
    Dec 13, 2002
    36
    dix hills, ny
    drop me an email and we'll talk
    phreak480@aol.com
    and that goes for anyone else that is interested too
  9. The_Sandman_454
    The_Sandman_454 1/2 ton status
    Sep 9, 2001
    209
    Michigan, USA
    Not all shops overcharge... Shop I deal with will peak/tune, convert if applicable, etc... They even go out of their way to find conversion information, and other info about tuning it up if they don't have it available... Charge about the going rate too from what I've seen... Same place if you buy an antenna from 'em they'll set SWR for free.. Some places are a *real* ripoff when they try to milk people on stuff like that...
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I hear ya there, it's just that I've noticed you can usely get the work done cheaper through a good radio tech doing it out of his house verses going to a shop. I used to live in Omaha, Ne. and we had a few radio techs that were really good, and they would beat any shops price, and usely do much better work, becouse they enjoy talking on the radio themselves.
  11. The_Sandman_454
    Sep 9, 2001
    209
    Michigan, USA
    I guess that's basically what this guy is, except instead of his house he gives the same great deals and service from his shop... Has a 2950 original model with an amp on it, and an A99 on the shop he tends to talk on, etc... /forums/images/graemlins/crazy.gif
  12. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    If you are near Denver, try Sapp Bros. Truck stop on Quebec off I70 or the T/A truck in Wheatridge, on I-70. The guy at the T/A, use to be reasonable...... $20-25. Good luck!
  13. spectr17
    spectr17 Newbie
    May 10, 2003
    3
    California via Mizzurah
    Ditto what Anonymous posted. From experience in working on CBs since the early 70s, Tweak n' Peak ain't worth it.
  14. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    a guy in an offroad club im in locally does mine for free! /forums/images/graemlins/thumb.gif
  15. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    ALL, I think the correct term is "Clean and Service"
    Since the legal limit is 4 watts and a shop could get in trouble for producing anymore out of a CB. Atleast that is the way i understood it.
    I think I paid $25.00 back in 1995 to have mine push to 16 watts after the clean and service. It made all the difference in the world.
