How much toe??? Need help
Discussion in 'The Garage' started by Bowtiedad, Oct 26, 2006.
  1. Bowtiedad
    Bowtiedad Registered Member
    Jul 7, 2005
    19
    Rochester, Indiana
    How much toe in do i need to get it close. I just bought the truck and it has new tie rods,ball joints,drag link and raised sterring arm, but the tie rod is adjusted too long. It is a inch wider at the front of the tires than it is at the rear of them. By the way it has 35's and a 6 inch lift it matters. Thanks Jim
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Start with 1/8" toe in.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    1/4" toe in is what I normally use on my truck.
    Harley
  4. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i heard u want at least 1/16 of toe...
  5. Bowtiedad
    Jul 7, 2005
    19
    Rochester, Indiana
    Thanks for the help guys. Jim
  6. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    that size tire 1/8 min to 1/4 max. these are for toe in specs. so as the tire pushes out it will be stright.
