How much torque for rocker studs on a BBC?
Discussion in 'The Garage' started by MousePowrd, Jun 27, 2003.
  1. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    How many #'s should I torque 7/16 rocker studs to on a 454?
    Thx
  2. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    My Comp Cams instruction sheet said 70 ft-lbs if using oil as a lubricant, or 50 ft-lbs if using Comps assy lube.
  3. MousePowrd
    May 7, 2003
    215
    Saginaw, MI
    thx a bunch
    Thats about the range I was thinking, similar to a head bolt. I think I will go about 60#
