How much tranny fluid???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by loudandproud, May 25, 2001.
  1. loudandproud
    loudandproud 1/2 ton status
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    How many quarts of tranny fluid does a 700R4 take?
    I am out changing my fluid right now (I'm a first timer here) so wish me luck.
    <font color=red>_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _</font color=red>
    <font color=blue>'90 Jimmy</font color=blue>
    <A target="_blank" HREF=http://loudandproud.coloradok5.com>http://loudandproud.coloradok5.com</A>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    5 quarts!
    My president is Steve Fox.
    90-350TBI-TCI700-241-33"-10 bolts w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    That's 5 quarts if you're just dropping the pan, changing the filter and refilling. If it's a new tranny with a new torque convertor, you'll need closer to 12 quarts. My Turbo 400 with the factory deep pan took 14 quarts the first time I filled it up. [​IMG] I'm pretty sure that the 700R4 takes slightly less. Somewhere around 10-12 quarts for a total fill.
  4. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    If you are draining the fluid and the filter you should just go get a bigger trans pan. It will hold 2 extra quarts of fluid. The one I got is cast aluiminum cost about 120.00 bucks. And I plan on getting an extra trans cooler. These auto trans like to burn up easy. I don't know just an Idea for yeah.....
  5. loudandproud
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    Could having to much fluid in the tranny make it so it won't shift out of first gear?
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Mine took between 4 and 5. Put 4 in and drive it a little, then add more if needed. I think you really need to have the right amount, havign too much is probably bad for it. make sure you get it warm enough before you add more, I didn't wait long enough, checked it and it was low, drove around for a while, checked it again, and it was really high. Harder to take out than put in.
    90K5
  7. loudandproud
    Jun 27, 2000
    451
    Ham Lake, Minnesota
    Thats the same thing I did, I didn't warm it up long enough before I added more fluid. I guess you learn from your mistake.
