how much trimming to fit 42s?
Discussion in 'The Garage' started by muddybuddy, Dec 2, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey there, ive got 8" springs and 1"zero-rates, with the front pushed out 1.5". im torn between 39.5's and 42's. im hoping that since im running such big springs, the truck wont flex enough to need to cut all that much to fit 42s. any idea how much id have to hack? this is my DD and its got a alost perfect body and i wanna keep it as close to that as possible with minimal trimming, but ive been reading about alot of ppl who got 39.5's and wished they had gotten 42's. i only do mud, so flex isnt that big of a deal obviously. thanks for any imput :D
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    you might want to ask surpip...
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    This was 6" spring 2" body lift and zero rates. Front axle pushed forward 1.5 and 42s
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    sweet, so it doesnt look like will be THAT much trimming :D
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    4 inch springs up front with a 1 inch zero rate pushing the axle fwd 1.5 inches and 2 inch longer shackle with a 6* shim.
    springer suspension in the rear. (Thanks Marv, some day ill be able to run it)
    42 inch TSL's.
    have yet to drive it.... shouldnt rub to much....
    Grant
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    52's up front with zero rate pushing the axle a total of 3.5" forward from stock.
    Net about 4" of lift.
    42's
    :D
  7. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Just look at the GMOTM for Dec. DP_90 has got 6" BDS Springs up front I believe and redrilled his D60 perches to move the axle forward ~1". He used bump stops to limit his stuff to run 42" Iroks. Looks real clean.
    GMOTM Dec 05
  8. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    koldsimer runs that exact setup. He has done a bunch of trimming, but he full flexes his rig all the time.
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    what do i need to do for the bump stops? do i need to relocate them, or get bigger ones?
