How much trimming?
Discussion in 'The Garage' started by uberbeans, Apr 17, 2006.
  1. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    First, I know about the first thread but I have to ask. Will I need trimming on my 5"front/ 6" rear lifted Blazer with 37" inch tires? If so how do I do this cleanly/professionally? I ain't skeered to cut!
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    then just put your tires on, cut it, and dont worry about it.
  3. uberbeans
    May 14, 2004
    564
    I don't want to cut too much or make it look crappy, though. Is there a technique to knowing how much?
  4. blazinjimmy
    blazinjimmy Registered Member
    Aug 28, 2003
    53
    I just followed the path of the inner fenderwells, towards the bottoms/front& rear-looks good. Cleaner cut lines than just hacking them off at an angle. I cant post pics...leave me email..I'll send pics.
  5. uberbeans
    May 14, 2004
    564
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Put your tires on and go somewhere where you can watch the truck with a buddy who know what he is doing get it flexed out until it almost is rubbing trim a little and repeat. You usually need to trim just a bit more than you think. It seems that just a bit out of the leading and trailing edges on the front and sometimes none out of the rear is what is mostly needed. To do a pro job use brand new blades and go slow. The last truck I did (36" swamper TSLs no lift) I used a sawzall and a grinder with a cut off wheel
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Where do you live?
  8. uberbeans
    May 14, 2004
    564
    I'll have to give it a try. To make my custom bumpers fit I already trimmed some and it might be enough. Thanks.
  9. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    i have 38's on a 6" and could drive with out trimming. I then cut following the inner fender well and slopped it towards the rear. I then folded the inner fender well, after cutting it off fender lip some, to the floorboard with a BFH.
  10. uberbeans
    May 14, 2004
    564
    What do you mean "folded the inner fender well"?
