How much weight can I tow?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by woodpecker, Apr 1, 2001.
  1. woodpecker
    woodpecker Registered Member
    Oct 19, 2000
    33
    Mount Vernon, WA
    Alright,
    I thought myself lucky that my '86 K5 still had the original owner's manual and documentation. But I'm not sure what the purpose of these documents was. They tell you great things like, don't try to drive it upside down. When going down really really long and steep hills, try putting the tranny in 2 or 1 instead of OD. Great, but if you want to know something more specific, you're screwed.
    I've got an '86, 305, th700r4, with 3.73 diffs. All stock. Hey I'm poor. I'm looking at buying a trailor, but am in the dark as to how much weight I can pull. The TRAILOR books suggested that the GM 305 can pull 6500lbs. Is this about right?
    Thanks!
    Woodpecker
  2. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    I'd say a safe bet would be 5500 to 6000 max. Usually trailer tow weights that the maker lists are how high they went before stuff started to brake..
    1991 GMC Jimmy, 350 tbi, stock for now, but not for long!!!
  3. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Well I tow a 21 foot Camper trailer that weighs about 5500 lbs with our junk in it. My Jimmy has a mild 350, 4 speed standard, 3.73's and at the time 35" General Grabber MT's. I never had any problems...
    I'd recommend a weight distributing hitch though.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I wouldn't recommend towing more than 5000 lbs(trailer and gear combined) with a 305. And make sure you install a heavy-duty auxilliary transmission cooler or you'll burn up your 700r4 in no time. I run a 22,000 GVW cooler on mine.
    One other thing- NEVER tow in overdrive.........
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  5. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    and.....always tow in drive not overdrive. My mech who has built many of trannys for us (2 subs and 2 k5s) stands by this. laways tow in drive and stuck around 55-65mph. Of course a cooler also. (tranny cooler guys)
    Ben
    www.BenjaminBone.coloradoK5.com
  6. Can Can
    15,552
    136
    Like I said....................?
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Also keep in mind that tow ratings usually are rated for someplace like Florida. Flat roads at sea level. Add altitude and mountains into the mix and things start changing really fast. [​IMG] Since you live in Washington, you'll need to think about where you'll be towing. Hauling a 6,000 lb trailer across the Cascades would be a long, slow trip (at least on the uphill side!). [​IMG]
    At least you have decent axle gears. 3.73's were what came in the axles automatically when you ordered the tow package. Install the biggest tranny cooler you can find and indeed, keep the trans OUT of overdrive while you're towing.
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Sure you can tow it, but can you STOP IT?? Make sure the trailer has good brakes and your K5 has good brakes too. Don't be afraid to downshift the trans to use engine braking...Oh wait, you already mentioned that.
    [​IMG] Semper Maintenance!
