how much will belts stretch?
Discussion in 'The Garage' started by LKJR, Aug 28, 2002.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    title says it all, I know my alternator bracket is huge on adjustment, the bracket I"m desinging for my york only has about 2" so how much do v belts stretch
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The technology that goes into making drive belts these days means that they barely stretch at all. However, a V-belt will ride lower in the pulleys as it wears, making it seem like the belt has stretched. The large adjustment available for the alternator accounts for slight variations in the actual length of new belts and leaves room to easily install a new belt. 2 inches may be plenty of adjustment if you use a belt that is on the tight side to begin with. /forums/images/icons/cool.gif
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    the v belt on mine stretched a good bit.ii had a 58 inch on mine and it stretched all the way to within 1/2 inch of the end of the bracket. that is after going around the harmonic, p/s, alt, and fan. sorry i didnt get you that pic i couldnt get ahold of a camera.
    nathan
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    np man on the pics, this belt is going around the ps, and harmonic then to the york guess I'll try it and see what happens
