how much would my compression change by going from 76cc heads to 67?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Aug 30, 2001.
    just checking out the s/r torquer heads on summit's page- dreaming about bolting on 30 hp.
    <font color=blue>Striving for K5 world dominance</font color=blue>
  1. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    It's not the HP that you will significantly gain by going down to 67cc heads, but the low end torque you get from them. I run a set of 67cc heads and love the extra torque I got from them.
    David
    <a target="_blank" href=http://www.extremeblazer.com>http://www.extremeblazer.com</a>
  2. J.R.
    J.R. Guest
    depending on the pistons and the thickness of the head gasket you could pick up almost 1point in comp.
    BIG BLOCK MAN
    "MORE POWER"!!
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    The Vortec heads are mo' better.... I've had both - and I believe the Vortec headed motor performs better - even with a smaller cam!
    If your 350 had 9.0 CR with 76's, it will have 9.9 with 67's.
    Marv
  4. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    The increase in compression all depends on the cubic inch size of the motor. I agree with Marv, the Vortec heads perform better and they are less expensive. Plus they are 64cc chambered insted of 67cc which will boost compression a little more. I am running the Vortec's and I love them. You can't beat them for the $. IMO
    '85 K5 : Run it til it breaks, then fix it and go again!
  5. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    it should go up by about 1-1.2 pts depending on the gasket thickness you use
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
