how much?!?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bassphreek, Apr 12, 2001.
  1. bassphreek
    bassphreek Registered Member
    Feb 17, 2001
    25
    nj
    how many quarts of trans fluid should I need. its a dry trans, dry torque converter, dry lines, and dry radiator. th350 trans. just need a ballpark here. thanks a lot.
    i like imports..........they make good speed bumps
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    12-14 should do it
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]
  3. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Pour a quart in the torque convertor, bolt everything up, then put 5 to 6 quarts in. Start it up and dump about 4 more quarts in. Check the level. Add enough to get it to the cold mark. Cycle it throught the gears secveral times (with the brake applied) and check again, and add as necessary. When it is hot enough bring the level up to just at or over the full hot mark. About 11.5 quarts, add more if your running a deeper than stock pan or an tranny fluid cooler.
