How often do you check steering gear bolt torque?
Discussion in 'The Garage' started by rcamacho, Jan 23, 2007.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    It's been about a year since I checked after having the frame patch and ORD brace installed. All bolts were loose. I've re-torqued all to 85ft/lbs. Seems like I'll need to make this a regular inspection before/after going offroad.
    Any credibility to upgrading to GR9 bolts?
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'd consider swapping in new bolts. I had some issues with tranny crossmember bolts loosening up over and over again, so I finally replaced them with all new bolts, washers and nuts and problem was solved.
    Grade 8's should be plenty fine.
    Rene
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I check mine after every 4-6 wheelin trips. After the first few checks a few years ago, they've stayed tight ever since.
  4. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    Never checked mine. Can you tell me where they are? They sound important
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Serious? If you are they are the 4 bolts that hold the box to the frame:D 5 if you have the bolt on brace.
    Ira
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    "Miniwally" is full hydraulic IIRC...:D
    Rene
  7. sandawgk5
    Oct 28, 2003
    6,881
    Damn rich fo(kers:doah::D
    Ira
  8. miniwally
    Aug 11, 2003
    3,069
    206
    Colorado
    Do you have to come here and ruin my fun.:p:
  9. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I check them pretty regularly if I remember to. They will loosen up from time to time. Installing new grade 8 bolts is a good idea. When I installed my new bolts I installed bolts that were about 1/2 longer then stock. 3 of the bolts you can get a nut on the backside of the steering box. I installed metal locknuts to help keep them from loosening. It seems to help keep them in there longer.
    Harley
  10. rcamacho
    Jul 1, 2004
    1,324
    WA
    I'm running new GR8 bolts that came with the ORD brace. I'll check them regularly and go with hightemp locktite next time.
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Right next to your front left leaf spring, ya moron.
  12. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    That's my job here Brandon...:D
    Rene
  13. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
  14. miniwally
    Aug 11, 2003
    3,069
    206
    Colorado
    I took off the visor and looked and couldn't find nothin there. I think the previous owner must have forgot to put that back on when he took it apart. I will have to ask him where it is.:p:
