How should I anchor my spare 42?
Discussion in 'The Garage' started by chvyhs, Dec 13, 2004.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I want to mount my spare tire inside my '90 Suburban. It's a 42" TSL on a Hummer beadlock and it weighs about 180lbs. I don't think mounting it straight to the bed floor will be strong enough unless I use a big plate underneath floor. I was thinking something about 6" square and 1/8" thick. I don't want to mount it to the roof because it's tall enough and I don't want to hang it off the rear because it's got enough rear overhang.
    So what suggestions do you have?
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Not real sure how the gas tank will interfere but what about putting some eye bolts in the floor and then running one or two ratchet straps across it. I know it sounds tacky but you could position the bolts as close to the tire as possible to avoid using too much space and then you'd have the ratchet straps on hand for potential trail repair type stuff.
    I doubt you'd need to reinforce the floor with anything more than a large fender washer since the straps wouldn't need to be more than really snug.
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    That's basically what I did.........bolted an eyebolt through the floor on each side of the tire and ran a ratchet strap over it (13/38-16 TSL on a 16x10 steel rim). I've been on about 4 tough trail rides and it hasn't moved yet.
  4. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    You have seen how I used to have mine. I had 6 eye bolts in the bed of the Blazer. 2 at the very rear, 2 in the middle and 2 in the front coming out of the seat mounting holes. The tie downs work very well. But you'd need more than just one. I had mine X'd over the top and it held it nicely.
    You have also senmy latest mounting. This will also work in the back of the Burb. Just run a piece of flat plate on the bottom side and bolt it down that way. Like someone above mentioned, your tank may be in the way.
    just break out eh welder and weld it to the floor.:D
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Put it on the trailer where it belongs. :D
  6. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    Not everyone has a trailer queen.
  7. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I have 8 cargo tie downs from a late model suburban bolted to the floor in the back of mine. They, along with 3 ratchet straps hold my 285 spare, 2 LARGE ammo cans, toolbox, highlift and spare D60 shafts to the floor. The work great.
  8. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    hey sorry to get off topic but i had a question for afroman. how much of that stuff on webshots is still for sale? and where r u from?
  9. muddyblzr
    Nov 2, 2004
    623
    o and i love the red suburban that thing is mean id love to c it up close
  10. afroman006
    Aug 21, 2002
    2,876
    Most of it is gone but has been replaced by other junk. What exactly are you looking for??
  11. muddyblzr
    Nov 2, 2004
    623
    im looking for a fuel injected 350 or 454, turbo 400, np205, 15X10 or 15X12 steel beadlocks, and maybe a 14 bolt id like one but its not totally neccessary for my DD
  12. muddyblzr
    Nov 2, 2004
    623
    where r u from?
